Use that same Toyota engine with an Eaton supercharger at 7 psi and get 243 hp and 174 tq. Ok, not earth shattering or anything, but still, nice bump up for a 1.8.
What kind of engineering crack do you have to be smoking to put a turbo on the Elise/Exige powerplant to run 380 hp and 280 tq?
I kidd you not. Forcfed has made a kit that puts a GT28 turbo and intercooler onto that engine. Double the HP and more than double the torque, all with 11.5:1 CR! Well, they probably are using thicker head gasket, so the CR might be down a bit, but the rod length and piston width (displacement) has not changed and they are using the stock crank.
Specs:
http://www.forcedfed.com/elise/turbokit ... ed380.html
In action:
http://video.google.com/videoplay?docid ... =forcedfed
Loose your license:
