For the engine,
It is a 347 cu in stroker motor. completely balanced, and ready to go with Edelbrock heads ported with new valves, springs, and roller rockers. Big cam, .582/.562 split lift, .282/.262 split duration roller Comp Cam designed for nitrous. Melling high volume oil pump, Moroso 7 quart oil pan, Keith Black pistons, H-beam rods, Edelbrock Victor intake, NX direct port spacer system, BBK 80mm throttle body. Fluid Damper balancer, Weiand polished water pump, custom made Taylor wires, 30# injectors, BBK shorty headers, BBK H-pipe with cat. converters, Flowmaster mufflers and custom tailpipes.
You can see some more pictures here, the most current ones are on page 2
http://www.cardomain.com/ride/2154592/1
I am looking to get $8000, which is close to what it takes to build this motor. The body of the car is in decent condition, and so is the interior. This car is a driver that has no problem going to the race track. I built the car to run just fast enough not to need a cage. I built the car with the idea that it would run mid 11's with the nitrous, and still be fun to drive on a Friday night. This car gets lots of looks everywhere I go, and it sounds great.
Oh, by the way it also has an Alpine CD player, Eclipse rear speakers, and Kicker 3-way set up in the front. I have 4" and tweeter Resolution seperates in the dash and 6 1/2" midbass drivers in the doors. I have nice Monster cable RCA's and speaker wire run to the trunk for an amp, but I have no amp back there. I also have an Optima Red Top battery located in a custom aluminum battery box in the trunk with 0 gauge wire run to the front of the car. I have really nice connectors/fuse holders throughout the car. Probably over $1500 in audio/cables/accessories.
