Hey,
I have this groovy Greddy Oil Pressure sensor addapter plate (sadwhich style) that goes between the block and filter. Only thing is that Maestro and I have taken a look at this are, he actually tried to install it but to no avail. I mean we can get it on there but can not see to locate a place that will allow the sensor to screw in without hitting something. There just does not seem to be enough clearance around it or you need some sort of right angle sensor if you will.
So, I am sure that some of you guys have this gauge in your car. The question is where did you tap into? How did you do it? Where can I get the parts?
I heard that there is some bolt on the back of the motor under the tmic somewhere but really do not know for sure. Please post if you have any info. I would much rather use the Greddy part as it is simple and cost me $70!
Oil pressure Gauge
- DamSedan
Oil pressure Gauge
I will always be the DRNWAGN!
- DamSedan
herecomesboost
herecomesboost
