Nabbad at all:
http://www.autoblog.com/2007/10/28/offi ... s-at-sema/
It's still a Chevy but should give the WRX a run for it's money.
New Cobalt SS/TC
- Phibs
New Cobalt SS/TC
Bryan
2012 WRX 5-Door Limited
Looking at the specs, that's going to be one quick little bugger. I'm not a fan of the seats, but the dash looks like the same build quality of the WRX. The HVAC controls look a hell of a lot like Subaru's. 4 port fronts means we'll probably start seeing these a lot more at the track.The standard transmission is the GM Powertrain Sweden F35 short-throw 5-speed manual with a "no-lift shift" feature. This, combined with the punchy turbo four, helps propel the Cobalt SS Turbocharged from 0 to 60 in a scant 5.7 seconds. In fact, GM set a Nürburgring class record for FWD sport compacts with the turbo Cobalt, lapping the Green Hell in 8:22.85. Better braking accompanies the added power with 4-piston fixed-caliper Brembos in front and vented discs with single-piston calipers in the rear. A driver-selectable competition mode with launch control can be enabled from the cockpit. Beyond that, the traction control system can be completely disabled.
It is a sad day when the WRX gets worse and a Chevy gets better...but in the end it is still a CHEVY.
