Code: Select all
% /usr/platform/sun4u/sbin/prtdiag
System Configuration: Sun Microsystems sun4u Sun Fire E6900
System clock frequency: 150 MHz
Memory size: 98304 Megabytes
========================= CPUs ===============================================
CPU Run E$ CPU CPU
FRU Name ID MHz MB Impl. Mask
/N0/SB0/P0 0,512 1350 16.0 US-IV 3.1
/N0/SB0/P1 1,513 1350 16.0 US-IV 3.1
/N0/SB0/P2 2,514 1350 16.0 US-IV 3.1
/N0/SB0/P3 3,515 1350 16.0 US-IV 3.1
/N0/SB2/P0 8,520 1350 16.0 US-IV 3.1
/N0/SB2/P1 9,521 1350 16.0 US-IV 3.1
/N0/SB2/P2 10,522 1350 16.0 US-IV 3.1
/N0/SB2/P3 11,523 1350 16.0 US-IV 3.1
/N0/SB4/P0 16,528 1350 16.0 US-IV 3.1
/N0/SB4/P1 17,529 1350 16.0 US-IV 3.1
/N0/SB4/P2 18,530 1350 16.0 US-IV 3.1
/N0/SB4/P3 19,531 1350 16.0 US-IV 3.1
========================= Memory Configuration ===============================
Logical Logical Logical
Port Bank Bank Bank DIMM Interleave Interleave
FRU Name ID Num Size Status Size Factor Segment
/N0/SB0/P0/B0 0 0 2048MB pass 1024MB 16-way 0
/N0/SB0/P0/B1 0 1 2048MB pass 1024MB 16-way 0
/N0/SB0/P0/B0 0 2 2048MB pass 1024MB 16-way 0
/N0/SB0/P0/B1 0 3 2048MB pass 1024MB 16-way 0
/N0/SB0/P1/B0 1 0 2048MB pass 1024MB 16-way 0
/N0/SB0/P1/B1 1 1 2048MB pass 1024MB 16-way 0
/N0/SB0/P1/B0 1 2 2048MB pass 1024MB 16-way 0
/N0/SB0/P1/B1 1 3 2048MB pass 1024MB 16-way 0
/N0/SB0/P2/B0 2 0 2048MB pass 1024MB 16-way 0
/N0/SB0/P2/B1 2 1 2048MB pass 1024MB 16-way 0
/N0/SB0/P2/B0 2 2 2048MB pass 1024MB 16-way 0
/N0/SB0/P2/B1 2 3 2048MB pass 1024MB 16-way 0
/N0/SB0/P3/B0 3 0 2048MB pass 1024MB 16-way 0
/N0/SB0/P3/B1 3 1 2048MB pass 1024MB 16-way 0
/N0/SB0/P3/B0 3 2 2048MB pass 1024MB 16-way 0
/N0/SB0/P3/B1 3 3 2048MB pass 1024MB 16-way 0
/N0/SB2/P0/B0 8 0 2048MB pass 1024MB 16-way 1
/N0/SB2/P0/B1 8 1 2048MB pass 1024MB 16-way 1
/N0/SB2/P0/B0 8 2 2048MB pass 1024MB 16-way 1
/N0/SB2/P0/B1 8 3 2048MB pass 1024MB 16-way 1
/N0/SB2/P1/B0 9 0 2048MB pass 1024MB 16-way 1
/N0/SB2/P1/B1 9 1 2048MB pass 1024MB 16-way 1
/N0/SB2/P1/B0 9 2 2048MB pass 1024MB 16-way 1
/N0/SB2/P1/B1 9 3 2048MB pass 1024MB 16-way 1
/N0/SB2/P2/B0 10 0 2048MB pass 1024MB 16-way 1
/N0/SB2/P2/B1 10 1 2048MB pass 1024MB 16-way 1
/N0/SB2/P2/B0 10 2 2048MB pass 1024MB 16-way 1
/N0/SB2/P2/B1 10 3 2048MB pass 1024MB 16-way 1
/N0/SB2/P3/B0 11 0 2048MB pass 1024MB 16-way 1
/N0/SB2/P3/B1 11 1 2048MB pass 1024MB 16-way 1
/N0/SB2/P3/B0 11 2 2048MB pass 1024MB 16-way 1
/N0/SB2/P3/B1 11 3 2048MB pass 1024MB 16-way 1
/N0/SB4/P0/B0 16 0 2048MB pass 1024MB 16-way 2
/N0/SB4/P0/B1 16 1 2048MB pass 1024MB 16-way 2
/N0/SB4/P0/B0 16 2 2048MB pass 1024MB 16-way 2
/N0/SB4/P0/B1 16 3 2048MB pass 1024MB 16-way 2
/N0/SB4/P1/B0 17 0 2048MB pass 1024MB 16-way 2
/N0/SB4/P1/B1 17 1 2048MB pass 1024MB 16-way 2
/N0/SB4/P1/B0 17 2 2048MB pass 1024MB 16-way 2
/N0/SB4/P1/B1 17 3 2048MB pass 1024MB 16-way 2
/N0/SB4/P2/B0 18 0 2048MB pass 1024MB 16-way 2
/N0/SB4/P2/B1 18 1 2048MB pass 1024MB 16-way 2
/N0/SB4/P2/B0 18 2 2048MB pass 1024MB 16-way 2
/N0/SB4/P2/B1 18 3 2048MB pass 1024MB 16-way 2
/N0/SB4/P3/B0 19 0 2048MB pass 1024MB 16-way 2
/N0/SB4/P3/B1 19 1 2048MB pass 1024MB 16-way 2
/N0/SB4/P3/B0 19 2 2048MB pass 1024MB 16-way 2
/N0/SB4/P3/B1 19 3 2048MB pass 1024MB 16-way 2
========================= IO Cards =========================
Bus Max
IO Port Bus Freq Bus Dev,
FRU Name Type ID Side Slot MHz Freq Func State Name Model
/N0/IB6/P0 PCI 24 B 0 33 33 1,0 ok pci-pci8086,b154.0/network (netw+ pci-bridge
/N0/IB6/P0 PCI 24 B 0 33 33 0,0 ok network-pci100b,35.30 SUNW,pci-ce
/N0/IB6/P0 PCI 24 B 0 33 33 1,0 ok network-pci100b,35.30 SUNW,pci-ce
/N0/IB6/P0 PCI 24 B 0 33 33 2,0 ok scsi-pci1000,b.7/disk (block)
/N0/IB6/P0 PCI 24 B 0 33 33 2,1 ok scsi-pci1000,b.7/disk (block)
/N0/IB6/P0 PCI 24 A 2 66 66 2,0 ok fibre-channel-pci10df,f900.10df.+
/N0/IB6/P1 PCI 25 B 4 66 66 1,0 ok pci-pci8086,b154.0/pci (pci) pci-bridge
/N0/IB6/P1 PCI 25 B 4 66 66 0,0 ok pci-pci8086,b154.0/network (netw+ pci-bridge
/N0/IB6/P1 PCI 25 B 4 66 66 0,0 ok network-pci100b,35.30 SUNW,pci-qge
/N0/IB6/P1 PCI 25 B 4 66 66 1,0 ok network-pci100b,35.30 SUNW,pci-qge
/N0/IB6/P1 PCI 25 B 4 66 66 4,0 ok pci-pci8086,b154.0/network (netw+ pci-bridge
/N0/IB6/P1 PCI 25 B 4 66 66 2,0 ok network-pci100b,35.30 SUNW,pci-qge
/N0/IB6/P1 PCI 25 B 4 66 66 3,0 ok network-pci100b,35.30 SUNW,pci-qge
/N0/IB8/P0 PCI 28 B 0 33 33 1,0 ok pci-pci8086,b154.0/network (netw+ pci-bridge
/N0/IB8/P0 PCI 28 B 0 33 33 0,0 ok network-pci100b,35.30 SUNW,pci-ce
/N0/IB8/P0 PCI 28 B 0 33 33 1,0 ok network-pci100b,35.30 SUNW,pci-ce
/N0/IB8/P0 PCI 28 B 0 33 33 2,0 ok scsi-pci1000,b.7/disk (block)
/N0/IB8/P0 PCI 28 B 0 33 33 2,1 ok scsi-pci1000,b.7/disk (block)
/N0/IB8/P0 PCI 28 A 2 66 66 2,0 ok fibre-channel-pci10df,f900.10df.+
========================= Active Boards for Domain ===========================
Power Fault HotPlug Board
FRU Name LED LED LED Cond.
/N0/SB0 on off off ok
/N0/SB2 on off off ok
/N0/SB4 on off off ok
/N0/IB6 on off off ok
/N0/IB8 on off off ok
========================= Available Boards/Slots for Domain ==================
Power Fault HotPlug Board/Slot Board/Slot
FRU Name LED LED LED Condition Assigned
There are currently no Boards/Slots available to this Domain
========================= Hardware Failures ==================================
No Hardware failures found in System
