[url=http://asa_project.gromnet.net/]Project URL[/url]
Install
Live version -
When you get into the linux prompt, type /asa/bin/lina. For the serial pipe, in vmware for serial port settings chose “use named pipe”, “\\.\pipe\vmwaredebug”, “This end is client”, “The other end is application”.Then download “vmwaregateway.exe”, start it with vmwaregateway.exe /t, use putty to connect to localhost, port 567.
Now start virtual machine, press enter on boot, switch to previously started putty and type /asa/bin/lina.
If you want the image to work in real pc instead of vmware be sure you have PCNET, Intel/Pro 100 or Intel/Pro 1000 card.
